Old 23-Oct-2011, 11:48 PM   #6
Try a simple, relatively inexpensive test... Pick up a preassembled coax cable, run it directly from the existing antenna to the receiver with the best signal meter. If you see a significant improvement in signal strength and quality, you need to continue locating the problem(s) with the existing cable.
Cable from a satellite system is compatible with OTA signals, many of the other components are not. Some satellite system parts look like OTA splitters but are not able to pass much if any OTA frequencies. If water has been allowed into the coax at some point in the past... discard it and start with new.
