Old 23-Oct-2011, 6:35 AM   #3
Using the ZIP code you posted, it's easy to see that there are many strong signals in the area. Most amplifiers would be overloaded.
Are you having trouble with reliable reception of any stations? Or, are you just wanting to see a higher reading on the signal meter?
As MM mentioned, the link to your TVFR needs to be re-posted, it looks like some characters got altered when you cut and pasted.
With a working link to your TVFR and a list of the actual stations you are having trouble with we can likely suggest one or more improvements that can help.
