Using a Terrestrial Digital High-Performance HDTV Antenna - 91XG with a rotor mounted on channel master eave mounts. The antenna is about 25 feet from the ground and about 8 feet above the roof peak. Coax is about 20 feet to the first set, with a splitter, amp and 50 feet of coax to the second set. According to
http://www.tvfool.com/?option=com_wr...60b5786e17f7e9  TV signal analysis results, it appears that I'm receiving all the "set top" (green) channels. On a good day, I receive FOX and PBS Charleston. However, I'm not receiving the "local" CBS 13 (Florence/MB) at all. I would think this antenna could do better than that. Thanks in advance for your consideration.
