Old 21-Oct-2011, 7:08 PM   #6
Jaytibee
Thank you ADtech
Yes - TVFool's modelling is extremely useful and has helped me a lot, but I must say that the KTVU location does not appear correct.
I am happy with the antenna that I have and cannot complain about the 70 didgital channels or so that I am receiving at my location, approx 18 miles from the towers.
The TV fool signal analysis does indicate that the KTVU station has an az of 150 from my location which would put it roughly due south. This does not agree with the actual sutro tower location channels which are in the az 250-260 range, roughly due west. Unless they have moved this station, something is amiss with the database, or I have a loose screw ! which has happened before.
I will confirm that KTVU is currently broadcasting from the Sutro tower.
Thanks for your time and I look forwarded to a continuing dialogue on this subject. I know signal analysis is highly subjective, but if others in the Bay area have experienced this irregularity from the sutro tower, then I would appreciate your comments
Thanks once again ADTech
John
Jaytibee is offline   Reply With Quote
