Old 20-Oct-2011, 3:20 PM   #4
There is a fundamental difference between digital cable (QAM) and digital Over-The-Air (ATSC) signal formats. It sounds as if the set is setup to receive digital cable.
You need to use the setup menu on your TV to switch from cable mode to 'antenna' or 'air'. You will then need to scan for channels.
You can search on-line for a copy of the user manual if you can't locate yours. You would need the actual model number of the set to be sure you get the correct manual.
