Old 25-Apr-2010, 5:06 PM   #6
donebu
Re: Multidirectional HDTV Antenna help
No, 25.1 often doesn't come in when pointed at 10.1. Also have too many TVs for a dual coax run with A/B switcher at each outlet.
Instead of a omni-directional antenna, I think I need something more bi-directional, because our main reception areas are nearly 180 degrees apart. The existing antenna is whatever Lowes had (about the size and configuration of a Channel Master CM 3679 Ultra Hi-Crossfire HDTV Antenna ) and is pretty directional.
Thanks for the link to the DIY bowtie site, I'll have to look whether I'll go with DIY or try something like the Antennas Direct DB8 Multidirectional HDTV Antenna.
Thanks for your help and suggestions.
donebu is offline   Reply With Quote
