Old 19-Oct-2011, 6:36 PM   #6
That is a challenging bit of terrain you're up against. I'd use 'the big guns', all roof mounted.
For UHF, an Antennas Direct XG-91, For high-VHF, the Winegard YA-1713.
If any of the stations on real channel 2 through 6 interest you, (there are some already on the air and others are pending, a Winegard YA-6260 is one option, The HD5030 is another option that would replace the YA-1713 at the cost of about 2 dB on channel 7 (KGO). When adjusting aim, an intentional tilt up at the ridge-line may eek out a bit more signal.
You would need a UVSJ for any of theses combinations. The XG-91 + YA-1713 + YA-6260 combination would need a HLSJ to combine the YA-1713 and YA-6260 signals before joining the UHF signals at the UVSJ.
A good low noise preamp such as the Antennas Direct CPA-19 will also be needed.
