Old 19-Oct-2011, 4:38 PM   #1
cmos
antenna recommendations
Map: http://www.tvfool.com/?option=com_wr...60b574ff057e52
Will mount on roof with new rg6 attached to chimney(approx 20 ft off ground).
Initially to single tuner 30 feet below but eventually might want to tie into existing coax in house with 4 TVs.
Reading docs on site and other posts looks like I need a high VHF/UHF antenna pointing at around 69 degrees off magnetic north to get all standard network channels.
There are some large trees in the backyard in the LOS to stations ~32 miles away.
Thanks in advance for antenna/amp recommendations
CMOS
cmos is offline   Reply With Quote
