Old 19-Oct-2011, 3:59 PM   #1
tkhk
Exclamation Installing 2 antennas answer please ASAP, Installer is on his way!
I had another thread going but no answer so thought I would start a new thread. My husband and I are new to this which seems to be a common first line to many posts as I've gone through many posts as to not bug you guys but alas, I am here. We have an (RCAANT3036WR) 60 Mile Long Range Antenna (just purchased for $56 from walmart) and Radio Shack 12-259 Preamp but am replacing it with a winegard 8700, also new. Here is our analysis...
http://www.tvfool.com/?option=com_wr...60b5e0b9a2e98e
Our issue is that we can not get channel 6.1 ABC and the 12.1 PBS is also very sketchy. We put the antenna on the top of the house aimed at 85 degrees. I am very pleased that we get the ION channel so do not want to change direction but thought that since we get 100% of the 3.1 KYW channel that seems to be on the same line as the 6.1 of which we literallly get a "no signal" option??? Any ideas? We do get (34 channels) all other networks including the CW. We are shooting for signal at three tv's. Would like to be able to run tivo also. I am curious. My husband travels a lot for work and this has been pretty stressful for him so I am hiring an antenna installer to move our antenna to the highest part of our roof and he is coming out on Today. At only $86 per hour I'm guessing it really should not take him more than a couple of hours. I am wondering if it really will be worth it to move it (I am guessing that it would go from about 25' high to 35' high) and And number 2, we did have another smaller antenna that did get the Harrisburg stations perfectly so is it possible to have him just add the other antenna to the mast or will we get some ghosting and need some sort of switch to go back and forth? We were hoping to add a DVR to the setup and if we need to add a switch then the dvr would not work if the switch was not flipped. It may be a crazy question but I thought I would ask. The other antenna was an RCA ant751R. I was extremely happy with the quality as it was rated for 36 miles and pulled in up to 55 miles, i just wanted to get a bigger one that was maybe more consistent with it's signal but if we added the smaller one to my larger RCA I would get all the channels I wanted...Thoughts? And Thank you!!!
tkhk is offline   Reply With Quote
