An amplifier is at the bottom of the list based on your TVFR.
If you are going to spend the money, be sure to buy from a vendor with a liberal return policy.
Also, be sure to select an amplifier with high input capacity, you have a lot of signal, most amplifiers on the market are going to overload.
CPA-19 and HDP269 come to mind...
I'm going on the record as saying, "An amp is not going to fix the problem".
If it changes the situation, I won't be surprised... I expect it to make things worse.
There may be a source of local interference in the neighborhood or something is loose or corroded.
