Old 18-Oct-2011, 1:18 AM   #3
MayfairWantsPBS39
Antenna CM 3016, is aimed at 274. Where most of the channels are. WPSJ comes in the back to the antenna, at 154. The person who installed the antenna said my location had unusually strong signals. He was surprised that WPSJ came in. He was concerned that the signals might be too strong, but we attached a set and everything was Jake.
I read your other post. Unfortunately I can’t quite figure out what numbers to put in where, to see if a DA would help. I bought one at a local retailer, and it made things worse.
If I remove the splitters going to the other sets, WPSJ comes in OK, with some pixelation. If I add even one splitter, it disappears. I’d like to have the ability to use 4 or 6: basement, living room, Tivo, sewing room, master bedroom, spare bedroom.
Cable run, from the end of the 56’ antenna lead to the other sets, is another 136’.
To compensate for 6 splitters, and 136’ of cable, what numbers on a DA should I look for, or what would a good DA be for this situation?
MayfairWantsPBS39 is offline   Reply With Quote
