Old 16-Oct-2011, 5:24 AM   #6
commandrew
Cool thank you for all the helpful info..
One problem; I should have mentioned the the attic space Im using is above my laundry room and the walls go straight thru to the ceiling. In other words the attic space I have is pretty small. It's about 9 feet wide, 6 feet deep, and 6 feet high. The antenna you recommended is 80 inches so I'm worried about it fitting if it needs to be rotated in a certain direction. It would only be a problem in the worst case scenario but I dont want to risk it. Do you have another recommendation that's a bit smaller?
Thanks again!!
-Andrew
commandrew is offline   Reply With Quote
