Old 15-Oct-2011, 10:32 PM   #3
John Candle
Tv Antennas and Reception
Your location is easy. I recommend 2 antennas , A http://www.canadapost.ca/shopper/sea...ywords=hd7697p aimed at about 145 degree magnetic and a Channel Master CM2016 , http://www.saveandreplay.com , aimed at about 60 degree magnetic compass. New RG-6 coax will be connected to each antenna and will be separate all the way to the location of the tv. Some tv,s have 2 antenna connections. If the tv does not have 2 antenna connections then a AB27RS A/B antenna switch will be used to switch the 2 antennas to the tv. The CM2016 antenna can be rear mounted to the tower structure below the HD7697P antenna that will be mounted on top of the tower.
