First off, of the top 5 stations on your TVFool report (the strongest signals), 4 are VHF stations, your antenna is a UHF antenna, and at roughly 50 miles away, you will be hard pressed to get those VHF stations with your antenna.
I would get a VHF antenna, and use a UVSJ signal combiner to connect to 2 antennas together.
The antenna gurus will eventually pop in here to give you their choices for a setup.
