Thread: Antenna advice
Old 14-Oct-2011, 3:00 PM   #3
Tower Guy
Originally Posted by pmat View Post
Today, without rotating, I am receiving pretty much all of the channels available in my area over the air with a radio shack antenna (about 9feet long) that is in my attic.
There is 74° difference between FOX and the other networks. The 9' long antenna is too directional. Combining a second antenna using a splitter may work and may not, it would be very trial and error. You could improve the odds greatly by adding a channel 23 bandpass filter in line with the antenna aimed at FOX.
http://www.solidsignal.com/pview.asp...Hz-%28BPF-U%29
An easier and cheaper solution (but not as elegant) would be a smaller antenna with less directivity. I'd consider the ANT751.
