Thread: Balun question
Old 13-Oct-2011, 5:54 PM   #2
The least expensive piece of equipment I know of that offers 'calibrated' measurement of signal levels is the SiliconDust HDHR3-tech which lists for about $300 US. The DVM won't measure RF signal levels.
Yes, baluns can vary in attenuation and frequency response. Expose them to the elements and they will deteriorate. The balun you describe sound like an indoor rated design... the cable company has little if any call for outdoor rated baluns. Once filled with water, it's junk.
Coax baluns work and are quite efficient... over a narrow frequency range. If you are only interested in one TV channel, you might make one work. Search for VK5DJ's Yagi Calculator.
