Old 12-Oct-2011, 7:52 AM   #2
Tvfool is being up dated after the Canada , August the 31 2011 digital change. The up date is a Big Project and will not happen over night. The Pending Applications Included is from before August 31 2011. The * next to the stations call sign show that it is speculative report. Not all Canada tv stations changed to digital , many are still analog and will be for a long time. Canada will have a mix of digital and analog tv stations for a long time. I recommend a Channel Master CM3679 All Channel Antenna mounted on a CM9521A rotor. The all channel antenna will receive all the tv channels , 2 thru 6 , 7 thru 13 , 14 thru 69. Tvfool is showing that tv stations are all around your location so the rotor will aim the antenna at them. I recommend go to the http://www.digitalhome.ca , forum for your area to get more information and updated information. Also here is more information , http://www.user.dccnet.com/jonleblan...da_TV_stations , http://www.tvtechnology.com/article/117022 , http://www.tvtechnology.com/article/105462 , http://www.digitalhome.ca/forum , http://www.saveandreplay.com , http://www.trentondistributors.com , http://www.friends.ca , http://www.crtc.gc.ca/eng/home-accueil.htm , http://en.wikipedia.org/wiki/Digital...ion_transition , http://www.canada.com/entertainment/...ion/index.html
