Old 11-Oct-2011, 4:12 PM   #9
Tower Guy
Originally Posted by sdvickery View Post
3.Please recommend an antenna that would be the best in this location and the Mag Azimuth to aim it...Do I go due South to split the two groups or cheat it towards the South-West since the South-East group NM is stronger?
That's the crux of the issue for you. The Detroit stations would do better with a larger antenna, but that same antenna will not pick up the Windsor stations as well. There is no perfect solution.
A smaller antenna than the HD7698P (Maybe the HD7694P) will barely work if a good preamp is mounted at the antenna.
