Tv Antennas and Reception
I recommend putting the HD7698P antenna on the bottom next to the tripod , the HD1080 in the middle and the FM antenna on top. You are correct about the spacing , how ever it is ok to just put some spacing between the antennas on the same vertical mast. This reduces antenna interaction and is usually ok. If a reception situation does develop to the point that a channel or channels are not received and you think it might be antenna interaction then the antennas can be moved further apart to see if that helps. The distance is between the elements of one antenna to an other antenna.
