Old 11-Oct-2011, 3:00 AM   #4
sdvickery
Steve
Thanks John for the questions about my config etc
I've stepped back and did a re-eval on where I'd like to go:
Instead of mounting the antenna in the attic as before I'd like to change its location, I'd like to mount an antenna on the large gable-end area on my home that looks directly South.
My station group’s directions are to the Southeast and Southwest, so hopefully a 23' high wall mounted/below the roof line on the wall antenna would work (Maybe the ClearStream4 antenna? It has a small footprint to fit my avail location and I could tilt it towards the Southwest channel group).
I currently have Comcast TV service ($105/mo) and Internet service ($48/mo). My goal is to drop the TV service and keep the Internet service. The internet will go into a Tivo unit and the antenna would supply the HDTV.
Our main TV and the Tivo unit will be together...and then another (6) TVs are located elsewhere around the house (All TVs have a good RG6 single run going to them from a single location where Comcast comes in now).
Can you suggest the best setup (ie? Gabel mounted Antenna>indoors 8 Way Splitter with built in Amp>runs to Tivo and all other TVs from the splitter) or a better/best way to do it.
Thanks Steve
PS.. Can the two channel groups that I'd like to see (Southwest and Southeast) be seen by one antenna at the same time or by any other manner?
sdvickery is offline   Reply With Quote
