Old 10-Oct-2011, 9:18 PM   #5
Comparing this post your earlier post, have you removed the second DB-8 and abandon the attempts to combine two DB-8 antennas into one coax?
It would help us if you could describe the entire system starting at the antenna(s), working step by step to the TV(s).
Which stations are received poorly with the antenna facing the towers? Please use the call sign and real channel number, virtual channel numbers are not relevant to the antenna system components.
