Outdoor Antenna Help
Hello, I have recently moved and am trying to avoid the added expense of cable/satellite tv. I am hoping someone could give me some advice as to the best antenna to install on my roof in order to receive the most channels. There is currently an old antenna attached to the chimney at about 25 feet off ground level. I would probably just replace this one. Here is my address in case that will help you guys to determine which antenna would work best:
3116 S County Line Rd
Johnstown, OH 43031
If you google map the property you can see that the house sits about 30 feet from some woods in case that would affect reception. The chimney/antenna is on the on the corner of the house nearest the woods.
Thanks for any help you guys can give.
