Old 8-Oct-2011, 2:35 PM   #34
Billiam
This may be a tuner problem. I've compared different TV's over the last couple of years and found while one TV would get every channel available, a couple others would note. Most notably a Sanyo that I purchased I had to return because it would not get the same channels as the Sony and Samsung TV's that I demo'd at the same time.
Try a good pre amp and see if that solves the problem. That Ch. 51 translator does show up as a Pending digital signal for the future. So, at least according to TV Fool it may eventually hit the air. I also went to the FCC database and unless I missed something about the application being dismissed, it is still planned to go on the air at some point.
