The Raleigh-Durham stations are less than 20 miles from you, an you should use a VHF-high-band plus UHF antenna aimed at 100 degrees as measured by your compass. I would recommend using a Winegard HD-7694P or an AntennaCraft HBU-33. if you are running multiple TV sets from the antenna, consider adding a small distribution amplifier in line before the splitter to be sure that you have enough signal for all of your TV sets. Good amps include the Winegard HDA-100 and the Channel Master CM3400
