Yes, try a pre amp. WIPX TV is a pretty weak signal and it appears as though you will need amplification to receive it.
But first, are you using a rotor or are you simply pointing the antenna in one direction? If the antenna is not pointed directly at WIPX then you will probably not receive it with this antenna. I'd try rotating the antenna first before using a pre amp. Since you have some strong signals in the area they could overload the pre amp and wipe out a lot of stations.
