"Can tropospheric conditions cause normally reliable channels to drop out?" is a perfectly legitimate question, stand alone or otherwise. I wasn't asking for any specific troubleshooting advice that would have required specifics about my particular OTA setup or channel availability, only if it could negatively impact TV reception. In the future I'll be 1,000,000 times more careful when I ask a question on this forum.
As Paul Harvey used to say.... And now, the rest of the story
When my reception problem continued the next day I again checked connections behind the TV and noticed the AC/DC converter for the preamplifier felt too hot, and unplugging it made no difference in TV reception. Prior to this, there would be no reception at all if the power inserter was unplugged.
I emailed tech support at Antennas Direct, got a prompt reply and instructions on troubleshooting the preamp. The inserter was producing 18v as it should and I also had 18v from my coax just before the mast mounted preamp. I also checked each connector for stray strand wires near the core and found none. Bypassing the preamp restored reception of 16 channels. I reported back to tech support and a new CPA-19 preamp is on it's way. Steve at Antennas Direct was quick to answer my emails and easy to work with. Thanks, Steve!
