Going after all possible.
Because you have multiple TV's, I'd suggest a second antenna. A Winegard HD7698P mounted on a rotator. This second antenna could serve one set, or both antennas could be cabled to each set, each equipped with an A/B switch to allow selection of the fixed or rotatable antenna as desired. Only one location would have rotator control.
With A/B or A/B/C switching you could opt for two or three fixed aim antennas.
If you are inclined to use home theater PC technology, take a look at this thread: http://forum.tvfool.com/showthread.php?t=820
