Quad shield is better then 2 shield coax . However for the 'test' , 2 shield cost less then quad shield. What I am recommending for the 'test' is get the problems that can develop with , amplifiers , splitters , couplers , coax , and etc. as close to zero problems as possible. Buy having the hook up like this , #1 antenna #2 simple plain coax , #3 connected direct to the tv. Also have a look at the the connections of the 75 ohm to 300 ohm adapter that connect the coax to the antenna.
