Reading between the lines a bit, simple and reliable reception of the major networks is your goal... with no rotator to argue over.
A Winegard HD7694P pointed at 80° compass, mounted on the roof or chimney would be my choice. There may be enough power to drive a passive 4-way splitter, I'd try. If needed, an Antennas Direct CPA-19 preamp could be added at the antenna mast.
There will be a few stations that may not be available to you, KTPX-ION being a notable one because it comes at you from an angle for which the antenna has little sensitivity. The group of stations at about 20° compass seem to be religious or spanish language programing based on my limited research.
If you want to receive every possible signal, a different solution can be offered.
