Old 6-Oct-2011, 7:24 AM   #4
Having a 2 direction antenna is desirable for reception at you location. The U4000 antenna can be easily made into a 2 direction antenna by lifting the metal latch of the reflector rods and turning the reflector rods from the horizontal position to a vertical position. The U4000 has 9 reflector rods and 8 , V , shaped wire reception elements. http://www.antennacraft.net/pdfs/U4000.pdf
