If you click on the "pending applications, digital-only" on your TVFool.com report, you will get the most accurate view of digital reception in your area.
Based on that information, Toronto is about 90 KM from your location, and the Kitchener stations are fairly close-by. You woulld probably best be served by using a deep-fringe all-channel antenna along with a high-input preamplifier and a rotator.
I would suggest a Winegard HD-7084P along with a Winegard HDP-269 preamplifier or an AntennasDirect CPA-19 and a good rotator like a Channel Master 9521a or an AntennaCraft TDP-2. The Kitchener and Toronto stations will be available to you if you make this choice
