If a power passing 2way splitter is needed , Antennas Direct has a power passing 2 way splitter that can be used to get the power to the preamplifier unit that is mounted at the antenna. If a power passing a way splitter is not needed then a simple 2 way splitter will be ok. Run the antenna coax into the utility closet.
