Old 4-Oct-2011, 9:15 PM   #2
Are you already 'testing' reception with an indoor antenna? If so, are you seeing all the stations you care about, reliably?
Based on the numbers in your report, I would opt for a large antenna installed outdoors.
Do you want full or nearly full converge of both Baltimore and Philadelphia stations? To do so would require a rotator or two antennas with A/B switching. Rotators are usually best suited to serving only one TV... viewers at additional sets will often want the antenna aimed some other direction.
