Most antennas are sold without accessory parts such as mast or cables.
The only caution I can think of regarding the Winegard is that once assembled, it can be difficult to fold back down. That would only be a problem if you put it in the attic and found you needed to move it outside.
Installed outside, it would be a premium solution, able to power many sets with no amplification needed.
You may want to 'test' your reception using the 4220 outside. There is a real chance you could find it capable when provided an unobstructed view.
