It's the C2V UHF/VHF high band antenna. As always , when a antenna is installed and is pointed at about the recommended degrees magnetic compass , As an example , if one is standing behind the antenna , the antenna is turned to the left and right to find a place that produces the strongest reception of the stations/channels that are being received. You are shooting for the stations from 294 to 228 degree magnetic compass.
