Thread: N00b Needs Help
Old 1-Oct-2011, 8:11 PM   #15
Tower Guy
Originally Posted by k3n0bl View Post
Is $325 about right? It'd be worth it if it works, but if not that's a bit of change to throw away.
$325 is too high. Use this instead http://www.solidsignal.com/pview.asp...Hz-%28BPF-U%29
Select channel 21.
Tinlee is right, the filter itself would not not eliminate channel 22. The pair of antennas are intended to drop channel 22 only enough to eliminate preamp and tuner overload.
Dave is right too. Reception of channel 21 may not be 100% reliable. It may be necessary to play with antenna location and/or height to optimize the signal.
