Old 29-Sep-2011, 4:55 AM   #7
John Candle
Tv Antennas and Reception
Your reception location is Not simple. The tv networks are spread around 3 directions. The strength of the tv signals range from very strong to Very Weak. I do not recommend using any type or kind of amplifier. The strong signals will overload the amplifier resulting in bad reception. I do not recommend putting the antenna in the attic , the weak signals will not be received. What I do recommend is a outside roof top antenna , a Winegard HD7697P antenna mounted on a ChannelMaster CM9521A rotor , Mounted on the roof of the house. Here are some antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com/34424560.html , http://www.ronard.com/engineered-rot...ount-3324.html
