Tv Antennas and Reception
A antenna rotor and antenna is a sources of conflict because other tv watchers will not agree where the antenna is pointed. A 2 antenna set up works very well , but will require triple the coax wiring and 3 A/B antenna switches for 3 tv's. Give the one antenna solution a try , if it does not do well enough , then the HD7000R antenna can be used to aim at the North East Group of Stations and an other antenna will aim at the south east group of stations and I will explain how to hook it all up with 2 antennas , 3 tv's and 3 A/B and 3 times the coax.
