Thanks for the quick reply. I have some room in my attic to work with and think I could get a decent size boom mounted up there which could rotate 360 degrees no problem. This will be my first install though so I'm definitely a newbie. For now, I only plan on hooking up 1 tv to the antenna which will have a run of about 30 feet of cable from the antenna to the tv. Depending on how strong the signal is I may decide to split the signal for another tv, but that isn't in the immediate future. Or, I may just install another antenna for the 2nd t.v. if need be.
