Old 28-Sep-2011, 4:01 AM   #2
John Candle
Tv Antennas and Reception
I recommend a Antennacraft U8000 aimed at 22 degree magnetic compass to receive the stations to the north north east. Here is how to aim antenna , http://www.kyes.com/antenna/pointing/pointing.html , for reception of the network stations , PBS , UNI , CW , CBS , FOX , ABC , MYNetwork , NBC , W67CD 23 Religion. The stations to the south , WFPX-DT 36 ION and WUNU 31 PBS are strong stations to the south and will likely be received through the back side of the of the U8000. To increase reception through/at the back side of the U8000 with the reflector rods in place on the antenna , the reflector rods can be removed by drilling out the rivets of the flat metal clips that hold the reflector rods in place. Removing the reflector rods allows more signal to be received by the V shaped metal elements that receive the signal. Here are places to buy antennas and etc. , http://www.antennacraft.net , http://www.solidsignal.com , http://www.amazon.com , http://www.starkelectronic.com , http://www.3starinc.com
