A high input preamp such as a Winegard HDP-269 or Antennas Direct CPA-19 would be needed.
Each tree is unique and would require some fabrication. Satellite J-poles come to mind when thinking of panel antenna mounting. Stainless lag screws are less likely to injure a live tree than Zinc coated.
The most important question you'd need to consider is 'can this be done safely?'
Spotting an active TV antenna is a bit too rare in my opinion, but yes, I occasionally see tree mounted systems. Before you go to the trouble, do you have a neighbor with a successful OTA system, too 'compare notes' with?
