The antennas designed for reception of channels 7-69 will provide some reception of FM signals. You can certainly try running a drop off the splitter to your FM receiver.
I would generally favor a separate FM antenna cabled to the FM receiver, independent of the television antenna system.
You can run an FM Fool report for your location and post the image of that report here. If you have one or more strong FM signals nearby, you may need to include an FM trap in the TV antenna system to protect the preamp from overload. If that's your situation, the only practical approach would be separate TV and FM antenna systems.
