Old 26-Sep-2011, 7:42 PM   #46
Thanks for letting me challenge the coax connections.
If you can find a 'test' location that gives the antenna a clear shot past the trees, yes, try it.
If you have a different ATSC tuner available, try that also. The signal levels shown on your TVFR would suggest that an unfolded paper clip should receive more than what you are presently seeing.
