Old 26-Sep-2011, 7:10 PM   #14
Billiam
Mileage comparisons for antennas are generally a sales gimmick.
My channel 17 is 85 miles away and a 2 edge signal. I also have a channel 15 that is 74 miles away and that was also improved with the CM 3023. The other signals are semi local at around 35 to 40 miles.
The 91XG is a decent antenna on the lower channels but if you need maximum gain then the best antenna out there right now is the CM 3023. Unless you can get your hands on a CM 4251 7 foot parabolic dish (now discontinued) you won't find a better retail store antenna for UHF low than the CM3023.
