Old 26-Sep-2011, 7:06 PM   #13
be236
Originally Posted by Billiam View Post
Check out this link.
http://www.hdtvprimer.com/ANTENNAS/comparing.html
Net Gain for UHF Only antennas. Antenna L shows real world gain figures for the 3023 aka the 4228. The 91XG is a very good antenna but its gain on the lower UHF channels is a couple db lower than the 3023. I've used both and my own tests on channel 17, 19, 21 and 24 confirms this.
Yes, I've been to that HDTVPRIMER site and even mentioned it in my earlier post about my concern for low-UHF channels and two people (see above posts) say that the 91XG is still better than the PR-8800, which is better than the CM 3023...
So your findings conflict with the other two people who wrote me above saying the 91XG is fine for low UHF as well.. hmm.... I dont know what to make of that...
... but again, the CM 3023 shows it's range is spec-ed up to 45 miles, while the 91GX goes to 70+ miles...
What was your broadcast tower distance in miles when you did your comparisons at those low UHF channels?
Also, that chart shows at channel 24 and higher, then the 91GX beats the CM 3023...
be236 is offline   Reply With Quote
