Those signals are too weak to be received with even a large indoor antenna in my opinion. You may be able to do it with a pre amp like the Winegard 8275 or Channel Master 7777 but I sincerely believe you will need to mount a large VHF Hi and UHF antenna with a pre amp on your roof to obtain most of the signals in red.
I'd recommend the HBU 55 from Antennacraft or Winegard 7698 for this situation. Either antenna combined with the pre amps I mentioned should give you ever signal down to the NBC channel as long as the antenna is mounted up on the roof.
