If you need a rotor I am going to recommend the following three units. I own them all and each one has worked perfectly through the past winter despite temperatures dropping below zero a couple of times and also during days when we had single digits.
NTE U105 and 106. The 106 is digital programmable. The Antennacraft TDP-2 is also a good rotor and can handle fairly large antennas. A lot of people gripe about the Channel Master 9521 locking up in the winter due to apparent bearing problems associated with the grease in the unit freezing. I did not experience this with my rotors.
