Marni13. Last year I stayed at a motel at exit 3 off I 69 in Fishers. I was able to get the Ion signal you mentioned while staying on the 2nd floor while facing Indy when using a Channel Master 4 bay 4221 antenna with my TV. I think mounting a HBU 33 on the roof will give you every signal that you need from the Indy area and also the VHF signal from Lafayette. BTW. I did this without a preamp. If you don't have any obstacles in the direction facing the weak signals then you probably won't need a pre amp. Just get your antenna on the roof and you should be fine. You may need a rotor though since your signals come from different directions. I needed to rotate my antenna inside the motel room by 25 degrees or so in order to obtain every Indy signal including the ION station.
