Old 26-Sep-2011, 2:00 PM   #1
LDPerry
Please help with Antenna choice
Please advise on my antenna options.
http://www.tvfool.com/?option=com_wr...60b5ee33db3da0
My first choice is to have an antenna in the attic since we often get a lot of wind from the river and across the fields. There are no trees or buildings around the house except for a line of trees 100 ft away on the edge of the river. Mostly 30-40 ft tall and to SW, W and NW. I tried a RCA ANT751 from Walmart and it does OK picking up Virtual channels 65.1, 8.1, 35.1, 6.1, 23.1 either inside or outside at about 6 ft above ground level and pointed roughly SW. Is there any hope for getting any of the weaker channels? Especially those to the NW?
An antenna in the attic would be at either 15 ft or 25 ft. The roof is 1/2 in ply with felt paper and heavy 50 yr shingles. Nothing other than the roof to obstruct a signal getting into the attic. We are pre-wired with coax feeds to 5 rooms from the crawl space. Will amplification be required? I have a RCA 10db amp from Lowes attached to the RCA antenna serving just one TV and it helped with drop-outs and stutter on some of the channels above but did not add any channels.
Thanks in advance for your guidance.
LDPerry is offline   Reply With Quote
