Old 26-Sep-2011, 8:18 AM   #1
be236
Reverse coverage Tvfool map?
Hi,
I have suggestion for new feature.
Instead of giving a map and signal colours for the channels in your particular location.. how about you provide a channel (station) and NM level, and the map shows you the circled-dot area where that channel at that signal level (or better NM level) on the map that you're viewing? Sorta like reverse 411, etc.
That way, if you're in the market to "move," you can know where to move to a location with your favourite station available?
be236 is offline   Reply With Quote
